Hi community;
How I can clone project settings? cause before there was an option of ?Shared whit an existing project. And Now I can't see.
Thank's
Hi Eduard,
These settings are still available, it might be confusing with the templates. When you create a new project, first you will select the template and then you can see the checkbox shared with the existing project.
Please let me know if its solved your problem or please share the exact screen where you were trying to view this option
thank's
