×I deleted a project and now I want to create another with the same name and I need to use the same project key, but I can't do it because JIRA say me that project key exists.
Any suggestion?
You need to clear the old key out of the database. But, it's being retained to prevent you damaging your historical data - it's only safe to clear the old key out if you have never moved issues from the deleted project out to anywhere else (or, if you have, you delete them as well)
We are using Mysql database,which command will delete project key from database.?Can you please help us.
Check the table "movedissues" first. If your project key is in there, you're going to need to do some external checks.
Hi @Mario Nunes
see, if you have deleted the project that time related project key also deleted.
If you want to edit the already exist project then you should be choose Edit project not delete the project.
as @Ligia Cindea mentioned above comment might be it works once you have performed Re-indexing.
I did it, but doesn't work.
