i wanted to integrate jenkins with JIRA , we have done this for JIRA on premise,same we wanted to do for on cloud jira, but i dont see any plugin availabe for jenkins integration with on cloud jira.
Please provide the suggestions.
Earliest help or guideline will be appreciated.
It has to be one-way with Cloud - you can't install addons to provide Jenkins -> Cloud-JIRA, Jenkins will have to do all the work over the REST interface.
hey thanks for the quick response. do mean to say that i have to install normal jira addon in jenkins and integrate with cloud jira- that is one way. and from jira to jenkins it won't be possible, likewise if i want to check for particular issue id,which build was execute.
As I said already, you can't install addons that provide. If you want to check issue-id vs build, you will need to get Jenkins to use REST to comment/update issues with the data about the build.
Thanks Nic for your answer, can you provide a link about how-to integrate Jenkins using REST JIRA Api ?
