×Hi, how can i add a permission scheme to a project ?
the posts i find refer to project settings -> permissions, but there is not such a menu item. i only have users in proejct settings and i cannot select a created permission scheme.
thank you for you help.
greetz,
Kurt
Hello @Kurt Callebaut
Currently this is an open ticket
Hi, thank you for the response.
i'm getting a bit demotived to setup jira. They promote it like everything is possible, but everything i try to configure turns out to be only in older versions, an answer that it is not possible or is an open issue.
i knew it was a mess to configure, but hoped on good support from atlassian, Seems also that is not a true story.
thx for your time, mate.
