I've been tasked with creating a project for an upgrade process. Simple scenario:
- set of about 8 major steps in the process (bunch of little tasks in each one)
- about 400 clients
- each client has be taken through each of the steps.
I'm currently considering creating each of the major steps as a workflow/column and each client as a task. Each client would then progress across the board through all the steps.
I think this structure would rule out using sprints - clients could take up to 10 weeks to upgrade depending on how quick their internal processes are. But I also think it creates the least amount of repetition and manual maintenance of the board (i.e. 400 tasks instead of 400x8 tasks).
I'm very new to Jira and don't have a lot of practical experience. I'm looking for suggestions or comments about issues this structure causes, so I can avoid some of the pitfalls I don't know about.
I think you're on the right track to setup 8 workflow steps. However, 400 clients would be a lot to see on a kanban board. I would suggest breaking them down to major groups based on your team's structure using components. For example: by regions (europe, north/south america, asia, australia). You can also filter them on the board by priority or using swimlanes.
Thanks for your response. We will be using Components and Epics to create 'mini projects'.
