How can I activate the JIRA System Administrators permission?
Luis Ramos October 25, 2012
It is not listed in the Global Permissions page neither the group jira-system-administration. I need this permission to export my data.
Jobin Kuruvilla [Adaptavist]
October 25, 2012
You won't get System Admin permission in onDemand. But you can export data without it. See https://confluence.atlassian.com/display/AOD/Exporting+issues
I don't have the option Import & Export > Backup manager.
Luis Ramos October 26, 2012
I'm sorry, I didn't see the workaround.
Thank you for your patience.
Gary
November 30, 2012
Hi Luis,
Per Jobin's comment, both of those groups are specific Atlassian Staff only groups used to perform updates and maintenance on OnDemand instances Only the Administrator group permission is needed fo accessing the Backup manager in the Administrator section of Jira.
Gary
