How can I add a comment and history to issue create screen.
prasanthi padmasale May 3, 2017
I an trying to add comment and history through json while creating issue via Rest API.But I am getting ("errors":{"comments":"Field 'comments' cannot be set. It is not on the appropriate screen, or unknown.","history":"Field 'history' cannot be set. It is not on the appropriate screen, or unknown."}}).
The comment field is always in hidden state, I am even not able to make it show by field configurations, show button is not didplaying.
And history is not at all their in field configurations.
edwin vasquez
July 30, 2022
Hello @prasanthi padmasale ,
Did you ever figure out a solution to this?
