How can I add a default assignee other than Project lead or Unassigned?
Sonia Rajput May 4, 2016
I need to add a user as a default assignee other than the Project Lead or Unassigned. For that I tried to add a post-function in the workflow with the field "Assignee" set to the "username". But it didn't work. Can anyone please provide any further suggestion how to do this.
Sonia
Sonia Rajput May 8, 2016
Hi Chris,
Here is the screenshot of the post functions added to the create transition.
Chris Dunne
May 8, 2016
Your screenshot is empty when I click on it.
Chris Dunne
May 9, 2016
Thanks. Could you confirm that your user has the Assignable User permission in the permission scheme for the relevant project.
Also, have you tried to manually assign the issue to this user in the Issue Detail View / Edit screen?
Sonia Rajput May 10, 2016
 Yes, our user has the Assignable User permission in the permission scheme for the relevant project.
Also assigning the issues to him worked fine.
Chris Dunne
May 10, 2016
When you used the workflow post-function, did the user who was running the workflow have the Assign User permission?
Sonia Rajput May 11, 2016
Sorry but I didn't get your point. Because if the user has Assignable User permission in the permission scheme for the relevant project then whenever an issue is created in the project then the issue should be assigned to the user as per the defined post function in the workflow.
So is there anything else that has to be taken care of.
cheers
Sonia
Chris Dunne
May 11, 2016
There are two relevant permissions. Assign Users and Assignable User.
The person that executes the transition which contains the post function will need to have the Assign Users permission. And they can only choose users that have the Assignable User permission.
Just make sure that the person executing the transition can also assign users.
I checked the permissions and the user has both the Assign Users and Assignable User permissions.
Sonia Rajput May 5, 2016
I have changed the order of the post functions but even that didn't work. For the components , I really don't want to  do that way because I have no components in the Project.
Chris Dunne
May 5, 2016
Can you post a screenshot of your postfunctions list on the Create transition?
Chris Dunne
May 4, 2016
Are you using components? If not you could create a component and assign a component lead. Then use a post-function to set the default component when you create the issue.
I am surprised the setting the assignee in the postfunction did not work. Are you sure there was no other postfunction that was overwriting your assignment? You may have to change the order of the postfunctions and move your postfunction down the list.
BarthélémyH
How would you use a post-function to set the default component when creating the issue ? I don't see such a post-function option.
Chris Dunne
May 11, 2016
Do you see a post-function to Update Field / Set Field Value?
BarthélémyH
Yes ("Update issue field"), but there is no option to update the field Components.
