How can I add a thin line separator on Create Issue Screen?
kalyani Prakash
November 1, 2018
I have multiple custom fields on create issue screen, need to add a line separator to differentiate the fields.
Please let me know if there is any way to get it.
Matthias Gaiser _K15t_
Hi @kalyani Prakash,
unfortunately, this is not an easy thing to do.
But maybe it works for you as well, if you put the fields on different tabs in the create screen. This way you can also logically group them to guide your users.
See also Atlassian's docs about tabs.
Matthias.
Timo Fitzner
July 3, 2023
Hey,
it´s a bit late but i´ve used a little workaround to achieve this.
Create a custom field ->  Message Custom Field (for edit)
and put it underscores as a default value and then you have your divider. :)
Tom Lister
Hi @kalyani Prakash
you could try putting a <hr> tag in the field description.
downside is its part of the field display so will move with field if you rearrange form.
