How can I check my logged work distribution? Worklog Distribution Gadget?
Mari Car
Hi Atlassian community,
I want to check the distribution of my work in the different projects. Which is the best way? Which filter could I use to check and control all my work logs?
I log my time in different projects and on some general unassigned tasks. I want to treck my time, how long I invest for the different projects.
I now set this filter "worklogAuthor = currentUser()" and put it in the gadget "Worklog Distribution Gadget", I choose "current week" but it does not work.
Do you know why? Any tips`?
Thank you very much in advance.
Beste regards,
Maria
somethingblue
February 5, 2018
Hi Maria,
I found a great discussion on this topic at Solved: How can I generate a report of time logged per person and not per task.  Most of the solutions are to use a third party add-on such as Tempo Timesheets, EazyBI or TimeTracker, however, others have written python and PHP scripts to deal with this and have posted links to their repositories in the thread.
Please take a look at Solved: How can I generate a report of time logged per person and not per task for more suggestions.
Branden
