I'm hoping to clean up the issues screen to only have the NEEDED buttons, fields and features we are using.
On server you can turn a lot of those off by disabling the modules that provide them (labels and the time tracking, no, not unless you turn of time-tracking entirely, which loses the work-log too). On Cloud, you can't disable the modules.
While I use the cloud as a trial, another department has a server install that I can tinker with. Where might I find the modules I can disable?
Admin -> manage add-ons -> select "all addons".
I'm afraid you'll need to work your way through them all to work out which ones provide the functions you want to turn off. Be careful to only turn off the stuff you are sure you don't want.
