Would it be possible to download an XML copy of all the issues in a particular project and upload them into another project within the same JIRA Instance?
JIRA allows you to restore a single Project from an XML backup, see Restoring a Project from Backup.
Since you want to restore (clone) the Project into the same JIRA instance, you should rename the source Project before doing the restore.
For example, if you want to clone Project SRC to TGT
I suggest doing a trial-run of this procedure in a test environment first. (You can easily create a test environment with your XML backup and the copy of the attachements directory you need for the first two steps.)
Additionally, if you are not afraid of XML, you can simply modify the XML (not JIRA recommended way, but I used it). However, you MUST definitevly TRY it first on a CLONE of your production environment. Sorry for the emphasis, but it's needed :)
You can use the JIRA Command Line Interface getIssueList to get all issues within a project. Then there are a couple of options to automate copying them into a new project. Either use createIssue, cloneIssue or runFromCsv to process. This solution is best if it is a regular thing you need to do with automation as opposed to a one time thing :). cloneIssue between projects requires JIRA Clone-Plus plugin
NEW: A new cloneProject CLI action is in progress - a snapshot will be available soon! See JCLI-153 - comments and suggestions welcome there.
jira-cli-2.2.0-SNAPSHOT-distribution.zip is a snapshot available that implements JCLI-153 . Tested on 4.2.4, 4.3.3, and 4.4-beta1. I would like people to try it out and provide feedback.
Bob, your cli-tools are fantastic! thanks
Hi Luiza, not specifically answering your question, but you might find this interesting:
Have a look at this plugin:
https://plugins.atlassian.com/plugin/details/15453
Specifically have a look at this documentation to see what it does:
http://www.customware.net/repository/display/AtlassianPlugins/CustomWare+JIRA+Utilities+Usage+Guide
You could set up a workflow transition to copy your issue to a new project, and then perform a Bulk Edit operation to transition all your issues (or just the ones returned from your search).
Not sure about XML but you can try exporting the issues into Excel, convert the file to CSV and use the in-built CSV importer to import it back to the new project.
http://confluence.atlassian.com/display/JIRA/Importing+Data+From+CSV
This would require all the customfields to be available in the target project as well. And the workflow should be same or else it requires a migration.
A feature request has been created for this, please vote for it: https://jira.atlassian.com/browse/AOD-6722
... as usual when there's a paid addon as a "workaround", apparently
