How can I copy a project?
George Carvill
March 13, 2014
I want to create a test project that is set up exactly like a live project. I am looking for a fast way to do this and figured the easiest is to copy the existing project without any issues in it.
Is there a way to do this?
Boris Georgiev [Appfire]
March 13, 2014
You can try out Configuration Manager for JIRA to achieve that.
After installing the add-on the steps you need to perform are:
  1. Go to the "Snapshots" page
  2. Create a "Project snapshot" of the "live project"
  3. Create a new project "Test Project"
  4. Go to the "Deploy" page
  5. Click "deploy" on the snapshot
  6. Select "Test Project" as a target project
  7. Go through the wizard and deploy
You'll have the new "Test Project" set up exactly as the "live project" but without any issues.
If you have any questions or need help with the add-on send a mail to support@botronsoft.com
March 13, 2014
George Carvill
March 17, 2014
That worked. Thanks!
March 17, 2014
Would you accept my answer ?
George Carvill
March 13, 2014
Thanks for the suggestion. But that's a lot of money for something I need to do.... well I don't know. I've been admin here for two years and this is only the second time I have wanted to do it.
March 13, 2014
So you can just use the trial version to do your job, you don't have to buy it :).
