×I want to create a test project that is set up exactly like a live project. I am looking for a fast way to do this and figured the easiest is to copy the existing project without any issues in it.
Is there a way to do this?
You can try out Configuration Manager for JIRA to achieve that.
After installing the add-on the steps you need to perform are:
You'll have the new "Test Project" set up exactly as the "live project" but without any issues.
If you have any questions or need help with the add-on send a mail to support@botronsoft.com
Here's a sample video http://www.youtube.com/watch?v=AbqSK1aG0dg
That worked. Thanks!
Would you accept my answer ?
Thanks for the suggestion. But that's a lot of money for something I need to do.... well I don't know. I've been admin here for two years and this is only the second time I have wanted to do it.
So you can just use the trial version to do your job, you don't have to buy it :).
