How can I copy fixVersions from parent issue to issues I am creating using the plugin?
Carlos Rincon
I am using JIRA Cloud Version and I am trialling the Project Automation plugin to automatically create some issues when a new Epic is created.  On these automatically created issues I want to set the Epic Link (to the key of the parent Epic) and the fixVersions (to the fixVersions of the parent Epic).  I can set the former via the Additional Fields JSON snippet, but I can't find the syntax that will do the job for the fixVersions.  Any help hugely appreciated!
Phyllis Zhu
On a related note, how do I copy the Sprint field?
What is the syntax for accessing the sprint field value so I can append it to the summary of the subtask I'm creating?
Nick Menere
December 9, 2016
Phyllis,
I've had a look and unfortunately it can't be done at this time. I've added an issue to track this as I think it is important to do - https://codebarrel.atlassian.net/browse/AUT-74
The current problems include the format with which JIRA renders the sprint on the issue. It is some legacy format that is of no use. The other issue is that it is an array (And not a single value).
We should be able to solve both these issues when the above issue is looked at.
Carlos Rincon
Hi Nick
Many thanks for your quick reply.  I tried the new option and unfortunately there seems to be a problem.  The issues no longer get created because of an error.  In the Audit Log I see:
Error creating issue    Version id '10404' is not valid
I should add that the issues I am creating automatically are not in the same project as the source issue, which may have something to do with the error question
BTW, I had been working around the limitation by adding a post function to my workflow to copy the fixVersions from the parent Epic, and adding a component in my automation rule to transition the newly created Epic to 'ToDo', thus firing the post function.  It's a bit hacky but it works..
Best
Carlos
Nick Menere
September 21, 2016
Ahh, you didn't say it was for another project.  I've just updated it so it should now work with different projects.
Carlos Rincon
Perfect - it works a treat!  Many thanks Nick.
Nick Menere
September 22, 2016
Great to hear!
Nick Menere
September 20, 2016
Hi Carlos,
I just implemented the ability to copy the original issues Fix Versions during Create issue.  I added the option "Copy from source issue" that should do exactly what you are after.
Let me know how you go.
Nick
