How can I create a hiearchy of issues with EazyBI?
Emmanuel Boukandoura February 12, 2014
1) I’ve created and imported a custom field which returns in a string the key of an issue link the present issue. I’ve imported this CF both as a property and a dimension. I'd like to an additional level member for this dimension (ie. issue) so that when I click on one value of this dimension, all issues which have this dimension name as property are displayed. I don't see how to do this with EazyBI. Any suggestion?
Emmanuel
Lauma Cīrule
February 16, 2014
Hi Emmanuel,
I just sent you an e-mail as well. Briefly, you should add the Custom field dimension together with Issues dimension on Rows and select "Nonempty" option. This will display linked issues.
Lauma
Manish Shah
July 20, 2015
Hi Lauma, I would like to do something similar. Can you please help me with the steps. Regards
Lauma Cīrule
July 23, 2015
Hi Manish, Please follow the instructions here https://docs.eazybi.com/display/EAZYBIJIRA/JIRA+Misc+Custom+Fields#JIRAMiscCustomFields-Issuelink to create a JIRA Misc custom field that would return issues with specific link type and then import this custom field as dimension to eazyBI. Let me know if you have further questions regarding this! Kind regards, Lauma / support@eazybi.com
Manish Shah
July 23, 2015
Thank you for your response. I read this. Interestingly we use JIRA OnDemand and cannot create Custom Field which is Calculated Text
Lauma Cīrule
July 23, 2015
In such case JavaScript calculated field can be used to get the Issue links. See more details here https://docs.eazybi.com/display/EAZYBIJIRA/JavaScript+calculated+custom+fields.
Emmanuel Boukandoura March 4, 2014
Thanks a lot Lauma.
