How can I create a project in Jira using Jira Java api?
BritikovMI
March 29, 2019
All the answers I've seen use the ComponentAccessor, which in turn issues an exception asking to initialize the mockito
  1. What, in turn, implies the use for testing purposes, do I understand it correctly?
  2. On the other hand, I need to create projects in real Jira, automatically
    How can I do that?
Thank you!
Tanya Gordon
March 29, 2019
Maybe try using REST Api for that... Take a look here
https://docs.atlassian.com/software/jira/docs/api/REST/8.0.2/#api/2/project
BritikovMI
March 29, 2019
Tnx! It works great
But I would like to create projects using Jira Java api
Mehmet Şirin Usanmaz
March 29, 2019
