How can I create sub task using Post function in Workflow?
Ramya Srinivas August 16, 2024
Cristian0791
August 17, 2024
Hi Shib,
Unfortunately, in Jira Cloud Standard, you cannot create sub-tasks directly using a post function in a workflow without using add-ons or custom scripts. Jira Cloud's out-of-the-box functionality for workflow post functions does not include an option to create sub-tasks.
shib saha
August 16, 2024
Hi @Ramya Srinivas , Better use the Jira automation for creation a sub-task after transitioning the issue to a certain status.
If you want to see how it can be done using the post function, here is the article for the same: https://community.atlassian.com/t5/Jira-questions/Create-sub-task-on-workflow-transition/qaq-p/1449436
Tomasz Kowalczyk
August 16, 2024
If you have any additional plugins you can achieve this f.e. if you have scriptrunner there is special postfunction which can do it for you
Tomasz Kowalczyk
August 16, 2024
i didn't saw that you're on cloud free tier but  ithink you can do it with automation rules
Tomasz Kowalczyk
August 16, 2024
Yeah, you can create it with very simple automation rule like this :
FREE
