How can I group issues in a Classic Project?
Rubab Naziri
October 12, 2020
I have a classic business project setup for my project. The task flow is pretty simple. ToDo > In Progress > Done.
In a classic project, you don't have Epics. How do I group my issues if I want to group them by business area?
Warren
October 12, 2020
Hi @Rubab Naziri
You could try using either labels or components. Using either of those, you can then set up filters which would show only those issues which related to a specific business area
Rubab Naziri
October 13, 2020
Thanks Warren! I shall try and let you know.
