×Application linking between atlassian tool suite breaks when requiring client side certificates on the reverse nginx proxy. Is there any way to force each of the tools to make their requests between each other use client certificates?
Hi Chris,
While this user in Solved: Application links when running behind reverse proxy isn't using nginx, the setup is similar and may help provide clues as to what you'll want to look for in your setup.
In addition to Solved: Application links when running behind reverse proxy, take a look at Solved: Atlassian apps not communicating after SSL install.
Branden
