Hello Community,
I am trying to consolidate information from various tools into JIRA for reporting purposes. I have successfully imported incidents from Remedy using a CSV upload and opted to use the the existing 10-digit ticket number as the issue key to differentiate the tickets from user stories native to JIRA (which were in the 3-digit range). However, after the importation all new issues and User Stories created natively are following the same 10-digit format as the remedy imports.
How can I go back to old 3-digit (soon to be 4 digit) format for native issues?
Best Regards,
John
Hi @John Drotar,
Please refer the following points with regard to how JIRA determines the sequence for Issue Key
In your case, you have two options:
Ravi Varma
