How can I load test steps along with test cases using Import tool?
Jennifer Anderson September 30, 2024
Want to load test steps along with test cases using an import tool.
3 accepted
Jennifer Anderson October 3, 2024
Thanks Ben and Andy - I reached out to Smartbear as suggested and they provided instructions and sample test step upload Excel file to use as a basis for importing test steps.  All good and working fine! Appreciate your help :)
Andy Barbet
Hi Jennifer,
You can search and ask questions specific to Zephyr Scale in their community forum, where I'm an active participant: Zephyr Scale Community
Regards, Andy
Benjamin
Welcome @Jennifer Anderson ,
Please could you provide more context. What exactly is the tool you're using for test cases and test steps. Are you. using a test management tool add-on to Jira? If so, which one?
If your just using Jira issues as test cases, you can use a CSV file and import it into your project.
Hi Ben - thank you for the quick response.
We have Zephyr by SMartBear.
I didn't mention the tool, because I don't know whether it is possible to load test steps through Jira OOTB Import tool or if we need to use an add-on tool.
Yes - we have already successfully loaded test cases, but we want the additional layer of the test steps to be imported.
Benjamin
HI @Jennifer Anderson ,
Thanks for additional context. There's actually two applications. Zephyr Squad and Zephyr Scale. Actually, there another one which is Zephyr Enterprise as well. It important to know which test management application as each of them have different ways of importing.
They have fairly good support. Worth raising a ticket to address exactly your needs with the test steps:
https://support.smartbear.com/open-ticket/
Here's the documentation for test steps for Zephyr Scale.
https://support.smartbear.com/zephyr-scale-cloud/docs/en/test-cases/import-test-cases.html
Thanks Ben,
Is it possible to import test steps using navigation "Jira - Issues - Import Issues from CSV"?
