How can I move a project with its issues/configs from one instance to another? (same version)
Leandro Nunes
Is there another way rather than project import option?
DavidV
Hi Leandro,
I think this is just another way of asking if a JIRA project can be cloned - which has been asked here:
https://answers.atlassian.com/questions/192/how-can-i-clone-a-project-in-jira
Theres no simple way to copy the configuration that I know of, but the CustomWare JIRA Utilities plugin, does have a Project Copy function, does copies some of the configurations.
Jo-Anne MacLeod
May 29, 2011
Anothe way that you can do this is to run a query, and then export all fields to a csv file, and import that csv file to the new instance. The downside of this is that you would lose your history. But at least the issues would be moved.
Ansar Rezaei
January 9, 2020
Hi
You could fully export and reimport it using this fantastic plugin:
https://marketplace.atlassian.com/apps/1211147/project-configurator-for-jira?hosting=server&tab=overview
Sameera Shaakunthala [inactive]
June 27, 2011
Export your JIRA data from the old instance into an XML file using the XML backup facility.
(Administration --> Backup Data to XML)
Using the same option, export the existing JIRA data from the new instance. If you do any mistake you may use this backup.
Import your project to the new instance, using the Project Import facility.
(Administration --> Project Import)
