How can I plan long projects, means longer than 2 years?
Albrecht Tiedemann
January 13, 2021
I tried to plan a three year project but the roadmap only allows two years as a maximum. How can I plan long projects, means longer than 2 years?
Albrecht Tiedemann
January 15, 2021
Dear Carlos,
thank you for your answer. I am testing several planning tools because our company needs a planning tool. But a 2 year limitation and a need to vote for such a basic feature (with no information when this will be available) leads to a negative result.
Best regards
Albrecht
Carlos Garcia Navarro
Hi @Albrecht Tiedemann ,
Unfortunately, the limit in roadmap is currently 2 years, like you pointed out. My understanding is that there were performance issues when the limit was higher than 2 years. There is an Atlassian ticket to allow to customize the timeline data range, I recommend you to vote for the feature.
https://jira.atlassian.com/browse/JSWCLOUD-17799
PREMIUM Trial
