×Hi there,
I am currently working with a DC instance of JIRA with approximately 1600 custom fields. My initial goal is to reduce that to 800. For additional context, our environment is moving towards standardised, shared templates, so the remaining number of older, custom projects is actively diminishing.
I've already walked through 2 phases of reductions targeting low-hanging fruit:
This has yielded me a scope of approximately 450 fields; however, that's not even close to my desired outcome.
My next target is in-use custom fields used by low numbers of projects. We don't intend to support hyper-specific use cases for custom fields in our future.
I have no idea how to produce this view.
What I'm thinking would be great would be a sorted list looking like the following:
Thanks, and looking forward to hearing back.
Hi @Matthew Martin ,
A third-party app like Power Admin for Jira can help you with the analysis and cleanup of your custom fields.
I would have used a database query to do that. Doing so you are sure to not miss anything due to permissions issue.
Regards
Yeah. Maybe I'll just need to bite the bullet and commit to doing that.
You can find the db structure below
https://developer.atlassian.com/server/jira/platform/attachments/jira_8.20_database_schema.pdf
You have to look into customfieldvalue table, join with jiraissue table then project table.
Make sure to check STRINGVALUE, NUMBERVALUE, TEXTVALUE and DATEVALUE column in customfieldvalue because if there is any value for a CF it's not stored in the same column depending on the field type in JIRA.
Regards
