How can I remove Jira project from Trash ?
Kowit Kowito
July 28, 2021
I am working on Jira Migration from Server to Cloud.
Last week I migrated one Project and I would like to remove it permanently on cloud. However, I cannot do delete it permanently on Trash due to it shows that something went wrong. We couldn't delete "one" Project.
Do you have any recommend to me ?
Carlos Faddul
July 29, 2021
@Kowit Kowito, you can access by the linking
https://YOURSITE.atlassian.net/jira/settings/projects/trash
I hope I helped you.
If this post was helpful, mark it as Accepted solutions, so you can help others who may have the same difficulties.
If your question has not been resolved, please post again with more details.
Kowit Kowito
July 30, 2021
Thanks this help to access trash console by a link.
However, I can fix it. You need to wait 5-20 minute after you did a submit "delete it permanently" and finally it will disappear from the console.
Like Carlos Faddul likes this
Carlos Faddul
July 30, 2021
@Kowit Kowitoare you need the project key to another project ?
