How can I use JIRA Advanced Roadmaps to track progress of an Epic/initiative?
Tanvi Jain December 14, 2023
I want to use Advance Roadmaps to know if any feature or  epic is on track/off track/at risk?
In the Atlassian video "How Atlassian Uses Advanced Roadmaps" - I saw a field "How are we tracking?". This is exactly what I'm looking for. How can I start using this functionality?
Mayuresh Kamble
December 14, 2023
Hi @Tanvi Jain ,
  1. Create a custom field of type Select List (single choice)
  2. Add options like
    1. On Track
    2. Off Track
    3. At Risk
  3. Add the new field to the custom field option in the Plans settings > Source Data.
Once this is done you can add the field using dropdown in the Roadmap and in the view settings you can sort them by the Color by option .
Mayuresh
Tanvi Jain December 17, 2023
Thanks @Mayuresh Kamble ! How will the value of this field be populated?
Mayuresh Kamble
December 17, 2023
You will need to set it manually
Tanvi Jain January 8, 2024
Thanks @Mayuresh Kamble ! Is there a way to configure working days in JIRA Advanceds Roadmaps? I know it can be done on boards, but not sure about Timeline view.
Mayuresh Kamble
January 8, 2024
That option is not currently available.
You can vote/comment on the change request for it here:
https://jira.atlassian.com/browse/JSWCLOUD-25523
Like Tanvi Jain likes this
Tanvi Jain January 11, 2024
Done.. thanks!
Mayuresh Kamble
January 11, 2024
Please accept the answer if you find it helpful
Thanks!
Tanvi Jain January 14, 2024
@Mayuresh Kamble Is it possible to do Capacity Planning on Advanced Roadmaps for Kanban based project?
Mayuresh Kamble
January 15, 2024
Yes the Capacity Planning can be done for Kanban projects also as mentioned here also you can refer to this Post for more information regarding the same.
Mayuresh
Pramodh M
Hey there,
Please find the webinar link here to get started with Advanced Roadmaps
There's also a paid course that dives into each concept- Link and finally documentation
Pramodh
