How can JIRA help manage resource allocation and requests?
John Evans
September 24, 2018
I am looking to utilize JIRA to manage resource allocation and standardize requesting format for my team. Ideally, something within JIRA that allows a user to enter information through a form or a wizard that will effectively communicate project information such as timelines and work needed, so that a resource can be allocated to the project. Additionally I would like to use a dashboard so that I can see which resources are over-utilized or under-utilized, and track project phase progress. Does anyone use JIRA for situations similar to this?
Jack Brickey
you will need one or more addons for this. I don't use these but will refer you to them based upon my knowledge. The first is a 3rd-party addon and the second is an Atlassian product.
John Evans
September 24, 2018
Thank you. Exactly what I was looking for!
Jack Brickey
You are most welcome. If your question is now resolved be sure to click the checkmark above to accept solution as it helps others when they have a similar question.
John DeRose
October 12, 2020
Like # people like this
Rahul Pardeshi December 9, 2019
Thanks a lot it worked
