You should be more specific:
The single project import will only work if both systems are the same version, also the project needs to be empty, it will not import into a project that contains any issues.
Dear Jozef Kotlár , thank you very much for your help, i think i have found the right way. I'll try it by your suggestion and tell you the result.
when i imported the test project, there was something wrong like this.
The backup project 'test' requires custom field named 'Last Closed Date' with full key 'com.tuncaysenturk.jira.plugins.jira-enhancer-plugin:last-closed-date'. In the current instance of JIRA the plugin is at version '2.4-SNAPSHOT', but this custom field was not installed in the backup data. You may want to create an XML backup with this version of the plugin installed.
Evidently you should have exact the same source and destination installations / including plugins.
1, I installed two instance of jira4.4 with the same installation.
2, I imported the data from v4.1 and v4.3 into v4.4 respectively.
3, I configured one v4.4 instance of jira4.3 reference other v4.4 instance of jira4.1, like import the new workfolw,workfolw scheme,permission scheme,notification scheme,screen scheme and so on.
4, export the data of jira4.1 from v4.4 and import into v4.4 instance of jira4.3 project by project.
Finally, i completed the data import from two instance running at the moment in parallel.
Not directly, may be a bit of scripting using Jira Command Line interface? Or a bit of coding with SOAP or REST?
Not plugins, via external programs or scripts that uses one of the above steps in Jira.
Btw, why not a direct upgrade an option? Is it that both the instances are running at the moment in parallel?
Yes. But i can't find out the right resolutions in the jira's documents.
