×Is it possible to clone Issues with their Subtasks, so that the Subtasks have the same Components like the Clone Issue ?
If you are in OnDemand nothing appears to be possible as you cannot add any plugins. Else I would have thought about adding a new transition with a post function using Script Runner to create a cloned issue with components as well.
but if i change the Component of the Clone issue (with Clone+) the Subtasks are still attached to Component of the Original Issue.
Is there a special Plugin for this function, that the Subtasks attached to the Component of the Clone Issue ?
Something like:
(Copy subtask and attach their Components to the same Component like the Clone Issue)
But I'm not sure if in ondemand it is possible to install plugins
