How can i create repetitive issue in jira?
Maxim Ryzhkov
February 3, 2016
I need to create repetitive issue by days, by weeks, by month in the business type projects. I can forget create new issues througth the time and to fix this I need opportunity to create repetitive issues.
In default JIRA functionality I didn`t find it.
Is anywhere there some add-on or another method wich can fix this problem?
viktorokolot
February 3, 2016
Hi @Maxim Ryzhkov
Have you tried the plugin TheScheduler?
Maxim Ryzhkov
February 3, 2016
It is exactly what I need but, unfortunately this add-on don`t support cloud version of JIRA. We use cloud version of JIRA and we need cloud solution if it is.
viktorokolot
February 5, 2016
Hi @Maxim Ryzhkov
unfortunately for the Cloud have are very few possibilities and plug-ins
