Is it possible to filter the issues that have an specific project related issues by JQL?
I'm trying to report the ratio of related issues from one project to another (Incident Management to Problems Management) to analyze how many incidents have resulted in a problem and how we can prevent them
For this requirement you can try out our plugin to track progress of issues in your cross projects Links and their status as well
Agile Tools - Epic Tree, Links Tree and Time in Status
The add-on allows you to visualize your Links hierarchy with option to view all your custom fields on a single screen.
Key features of Links Hierarchy:
You get multiple other features as below in the same app
With standard JQL, you can only get a list of issues with links and export them to Excel for further processing. This works if you want to do a one-off analysis.
Standard JQL doesn't easily allow it, but you can find the results quickly using our professional indexing service:
After you install the app, you can simply search:
linkedByIssueProject=PM AND project=IM
Check out the documentation to see more examples.
I hope this helps!
Daniel
This is not possible with the native filtering functionality in Jira. There may be a third party app that provides this functionality.
