How can i retrieve Issue Id associated with Custom field
AKASHB
Can any body tell me How can i retrieve Issue Id associated with Custom field?
AKASHB
i hae finally retrieved the custom field value using Componentmanger.getCustomfieldValueByName().
Nic Brough -Adaptavist-
July 9, 2013
This question does not make a lot of sense, you'll need to explain it in more detail.
The reason I ask for more information is that custom fields and issues are not directly related. An issue ID points at an issue. A custom field is an object that tells us about the shape of some data that might be associated with a specific issue.
There is no relationship between them. If you pointed at a custom field and said "what issue ID is associated with that field", the response is "none, you don't tie issues to custom fields, or vice-versa". A similar, but actually useful question would be "Can you tell me what issues have data for that custom field?"
But I can't guess what you mean from what you've written.
Christian Czaia [Decadis AG]
July 9, 2013
Could you explain what you want in more "detailed" way?
