I want some tools which help me to make perfect dasboard which allows me to know the status of of project and give all neccesssary deatils about my project
Hi @venom76966 ,
Welcome to the community!
Atlassian is shipping 30+ gadgets that you can use to create the dashboard you need. Create a dashboard (any user can do it) and then go explore!
On top of that there are also pretty awesome apps you can purchase to extend the reporting capabilities even further.
As a start I would recommend
By your question title it seems like you are requesting a report to look for individual user performance. You can choose "assignee" as your issue field to split a pie chart or a two dimensional filter statistics on to see who is assigned to most tickets, Who closed most tickets last week etc.
BUT, a big but, it is not the whole truth. In Jira anyone can close anyone else issues, issues varies in size and complexity so doing a simple number report will not be totally fair and constructive. I generally tend to think that any type of reporting, if made publicly aware to the team, will affect the user behaviour. Example: if you will pull reports on issues closed per user each week and have the individual measured by this you will soon see the behaviour of the individual to try to choose as easy issues as possible to get their number up, which is of course counterproductive for team and company.
all the best
/Lisa
