How can we manage test case execution?
Rave Nir
as i understand in the on demand version of Jira it is not possible to add the plugin Zephir that allows test case execution and managment.
is there any other way to do it in the on demand version?
Chris Miller
October 23, 2012
Hi Rave,
The Enterprise Connecter does only a simple task of sending defect metrics from JIRA to the Zephyr Dashboards in the Zephyr Enterprise or Community Editions.
The Zephyr Enterprise Edition and it's little brother the Zephyr Community Edition are seperate tools that manage testcases and integrate with JIRA On-Demand.
Check them out here:
http://www.getzephyr.com/buy/index.php
And of course note that the community edition is free!
Kind Regards
Chris
JohnA
October 22, 2012
Hi Rave,
You are correct that you cannot install the Zephyr for JIRA plugin, but we did recently bundle the Zephyr Enterprise Connector plugin on the OnDemand platform, so I would suggest that you setup a Zephyr Enterprise account and connect that to your JIRA OnDemand instance for your test case management needs.
All the best,
John
Rave Nir
Hi Jhon and thank you for your answer!
After enabling Zephyr Enterprise account in Jira how can I start to use it through Jira?
Best Regards,
Rave
