How create an issue with information from other issue
Carlos Ramirez
Hi team
I want to create an issue using information of the fields that the user type on on the screen when the user closed the issue.
I know I can automate the process, but I do not know how can I take the info of the fields.
Thank you
Steve Long -Evelon-
May 26, 2023
Hi @Carlos Ramirez
I think you'll probably want to use Jira Automation for this. (there's a specific action for copying fields from the trigger ticket)
You'll need to essentially set-up the following rules:
  • Go to project settings
  • Go to automation
  • Create new rule
  • Trigger: Ticket transitioned to 'Closed'
  • New action: Create Issue
    • Choose the field which you want to copy the value to
    • Click "..." and choose Copy From
    • Choose from the "Field to copy value from" the field from which you want to copy the value from.
Hope that helps - Steve.
Carlos Ramirez
Thank you Steve.
Excellent answer
Like Steve Long -Evelon- likes this
Carlos Ramirez
@Steve Long -Evelon-
Excellent answer.
FREE
