How create classification level.
this link to the documentation is Broken
https://support.atlassian.com/security-and-access-policies/docs/manage-classification-levels/
regards,
Hi @Mélanie Liguet,
The 'Create a classification level' page also is broken on my side. Here's how you can create one:
This video can help you as well: Data classification levels | Getting started with Atlassian Guard Premium | Atlassian.
Hope this helps!
- Manon
thanks for this very quick answer.
unfortunately in my case it is not so simple, I do not have the button.
However I do have atlassian guard
Ah you're indeed missing the 'Get started' button:
Can you confirm you're on Guard's Premium plan (and not Standard)? Are you an org admin? You can check in the Users directory if you have the 'Org admin' lozenge:
damn,
you're right. I'm not in premium on this product.
Thanks for your feedback
