×I was toying around to get a good plan in Portfolio and I decided to exclude some epics from the plan. How can I add them again? I've tried the suggestions found in other questions, but editing the sources doesn't fix my problem.
Hi Bram,
To re-add issue that were excluded from the plan, you should be able to do this by "edit issue sources" option in the plan configurations.
The walkthrough on the steps would be:
Go to "the Plan >> Configure >> SOURCE DATA >> Issue sources" and select the "Edit Sources" option
Then Select Next to get to the "Confirm what's in scope" page and select the check box next to any of the excluded issues to re-add them to the scope.
Click Done and the issues should be back in your plan.
What behavior are you seeing when doing this?
Earl
Hi Earl,
I've managed to readd them, but I had to remove the exclusions from the list of uncommitted changes.
