I currently have a system that changes issues from done to archieved on every friday, but that's with a custom status...
Is there a way to use and make it automized with what jira has? For example, with the system I made, user's have to check the archieved issues in issue filter, but I'd like if it could show on the Archieved Issues Tab that's under your project.
I apologise for any linguistical mistakes.
Unfortunately, we don't have a way to archive issues via automation or bulk issue updates. There are suggestion tickets for both:
Automation: https://jira.atlassian.com/browse/AUTO-1684
Bulk issue archive: https://jira.atlassian.com/browse/JRACLOUD-85101
Since this is a new feature, these feature requests don't have enough votes. Please add your vote on these tickets and watch them so that you’re notified if this is implemented in a future release. You can also comment on these tickets if you have any feedback or inputs for the product teams.
For now, you may explore Atlassian Marketplace for any apps that may offer these functionalities.
Thanks for your reply Karan, I'll look into the apps you've sent.
