×Community moderators have prevented the ability to post new answers.
This question should be getting a new answer. You can indeed create a new project with an existing project as a template.
- When you create a new project from a template, that project is created with its own fresh set of schemes. These schemes are:
- a permission scheme
- a notification scheme
- an issue security scheme
- a workflow scheme
- an issue type scheme
- an issue type screen scheme
- a field configuration scheme
https://confluence.atlassian.com/adminjiracloud/defining-a-project-776636280.html
Works for JIRA 7 and above.
@Timothy Chin can you tell me exactly how to create a new project with an existing project as a template. that will really help me so far
From the documentation:
"When you are creating a new project, select Create with shared configuration to select an existing project and to use that project's schemes. Note that when you're sharing schemes, any change to the scheme will affect all the projects using that scheme."
Well, this does not copy anything. However, quite handy.
Specifically - it doesn't copy the components from the previous project :(
Definitely need the ability to copy an entire project
hi, does anybody know whether any of the cloning project add-ons you can get on-line enable cloning of other add-on data? I'm working with ATM as a Test Management Add-on to JIRA and want to be able to clone a project including Test Management set up so that I can have a full project template complete with TM aspects for use by new projects.
Ridiculous? Not hardly. Dismissing this feature out of hand is shortsighted.
It's completely insane this is feature is not available as default. Cloning a project for repeated engagements is not an outrageous idea.
We've just released an update of our Jira cloud app Deep Clone for Jira that enables you to clone entire projects, including issues, configurations, components and versions.
You can access the new feature over the bulk clone dialog. Just select "Clone project..." as target project.
Please note: Currently this feature is only available for classic projects due to technical reasons.
Let us know if you have feedback or questions about this update.
The pricing depends on the size of your Jira instance. Here you can find more details about the pricing of Deep Clone for Jira.
Atlassian, no solution for this in 6 years (besides paid 3rd party apps) ... seriously?
Isso é tão básico... ter que configurar um projeto todo do zero toda vez que criar um é muito iniciante... no asana.com isso é default
Pode botar mais um ano aí...
This is really inconvenient. Clone of a project should be really easy to add as a feature.
So do we have any concrete way of cloning the project, When I say "Cloning", Literally copying everything. (Just a clone of my project)!?
It's crazy that you can't have project templates that INCLUDE issues/tasks, and be able to create a new project that includes everything. So frustrating.
JIRA Core is pitched as a Marketing Project Management solution and we have so many projects that have the same implementation. To create a clone of all the issues from the template project takes about an hour, when it should be a simple click.
true
Hi David, hi Pieter-Jan,
if you have to clone the template issues on a regular basis it's maybe more cost effective for you to work with Deep Clone for Jira.
With our cloud app it's possible to bulk clone more than 1000 issues at once. You can also move the issues to another project while cloning.
If you have questions or feedback don't hesitate to get in touch with us at support@codefortynine.com.
Update Nov 25, 2020:
We've just released an upate for Deep Clone for Jira that enables you to clone projects, including issues, components and versions.
You access the new feature over the bulk clone dialog. Just select "Clone project..." as target project when configuring your bulk clone.
Please note: Due to technical reasons, this feature is only available for classic projects.
We're curious to get your feedback about this update.
Has anybody found a solution to having a project template which includes a set of default tickets that can be used when creating a new project?
It seems like something that should be relatively straight forward, so I'm thinking I'm missing something, but judging by previous comments here, it doesn't seem like this is functionality that exists.
Can I bulk clone a list of default tickets within JIRA does anybody know, using the Bulk Edit function?
With our cloud app Deep Clone for Jira you can bulk clone up to 5000 issues at once.
Don't hesitate to get in touch with us at support@codefortynine.com if you have questions or feedback.
As mentioned in my post above, we've released an update recently that enables you to clone projects, including a set of tickets.
Let us know, if you have feedback about this update.
issue dates back to 2013. Still, it seems to me like a solution is pending. If only the bulk changes to issues allowed the option "clone to another project" it would save a lot of time in a relatively simple way
Hi, there's a paid App: ScriptRunner can do the clone.
FYI: How-to: Copy a Project Script - ScriptRunner for Jira Server
The built-in ScriptRunner script to copy a project worked like a champ.
Thank you.
I can't believe there's no solution for this. Most development and project management apps have this feature.
Hi Luciano,
Alternatively, if your instance is not compatible with the plugin mentioned by Timothy, you could use the JIRA CLI plugin as mentioned in this KB - Clone/Copy and Entire JIRA Project
Or, if you're just not that keen on plugins, you could do it the old-fashioned way : Exporting a backup, and then performing project imports.
We use Jira OnDemand, will the JIRA CLI plugin also work here and how would the CLI command look like?
Yes and here is the documentation link: JIRA Command Line Interface.
More specifically, you will need the cloneProject action with the parameters that match your requirements. It provides granularity in what aspects of the project to copy, so you need to specify.
But don't I have to buy that plugin license to be allowed to use the JIRA CLI which is not available for OnDemand?
Yes, I recommend a trial license to verify this is a good solution for you.
I cannot understand why my credentials don't work even if I am an admin
Just to update this thread.
Just remember that changes to the original will affect the clone. you can, however, customise your new project separately (I assume that if you then change the original it only changes the non-customised parts).
What does this copy exactly? All the schemes associated with a project? (Issue Type, Workflow, Screens, Fields, Permissions, Notifications?) Does this ALSO bring over the Components? I need a global field with the same data inside every single project at our organization and would like to use Components in this manner but hella forum posts suggest this is not possible to use as a global field. This seems to be a VERY common request.
We don't have a "Jira Admin" position at our company and we don't want to lose ANY engineering velocity setting up a new project with the appropriate fields/data. We want to empower engineers to make new projects with ease. Please help.
Give the above suggestion a try and then check the results to confirm if it carries across your desired settings.
Ooo Ooo I know the answer: it doesn't.
The specific item that Kateri was asking about is Components, and these are not copied in projects created with shared configuration.
In fact, that is why it is called "Create with shared configuration" and not "Clone", and also why this isn't the solution for this question.
Typically, people who are looking to clone projects want to do so because there are items like components and even tickets that should be cloned - the default set of tickets that all projects should have.
Hello All,
Any news for this? Should be really easy to do, just duplicate a project.
Still can't clone a project but the workaround is to clone issues. Since you can perform mass actions to them in the issues navigator and can find all necessary issues in a given project with needed criteria.
Hi Luciano,
You can use the Copy project buildin script.
https://jamieechlin.atlassian.net/wiki/display/GRV/Built-In+Scripts#Built-InScripts-CopyProject
Regards
Onkar Ahire
I did this the other day and was able to copy a project, the entire set up, permissions, workflows, permissions, everything. It was awesome. This is available when you click to create a new project, there is an option to "share settings with an existing project", when selected, it creates your new project with all the settings from that project you choose.
This is not a clone, as other have observed.
This is what it says it is: a new project with shared settings.
A clone would have a copy of all tickets, so the master serves as a starting point for new projects with all the same default tickets etc.
@[deleted] Yes, you are right, I am looking for a full clone of a project from classic to Next-Gen, Not just the settings.
@Erika Sa Can you please help us with this?
