How do I create a chart mapping number of open issues where the 'open' status is a custom field.
Sinead Ni Longaigh
January 24, 2018
Instead of using the default Status field, we created a custom field with more varied values. Lets call this field 3VStatus
I want to get a chart view for a group of issues, showing over time the number we are closing i.e. where the 3VStatus is Closed.
Aron Gombas _Midori_
You can do this with Better Excel.
It already has a created-vs-reported-report.xlsx template. You could change its logic to export the time when 3DStatus was set to Closed (instead of just exporting Resolution Date) and then:
jira-created-vs-resolved-pivot-chart
Nic Brough -Adaptavist-
January 24, 2018
You'd need to find or write a reporting add-on to provide that.
The closest you can get off-the-shelf are the "created vs resolved" gadget for the dashboards (which relies on the resolution), and there are other gadgets and reports which work off the workflow status.
If you used status properly, or mirrored the extra status to it (i.e. don't let people set the 3Vstatus to "closed" unless the process genuinely has ended in a closed actual status), then you'd be able to use the standard reports.
