How do I create a checklist within an issue
Joseph Cooper (CONT) February 12, 2019
Add checklist to validate approvals needed to move story to Closed status
Sebastian Brudziński
Hello.
There are a lot of great apps available on the Atlassian Marketplace that introduce checklists directly into the Jira issue view.  They can be used to track approvals and other requirements that you may have before marking the issue as done. One of the available apps is Multiple Checklists for Jira that we have recently developed at SolDevelo. It's available for Jira Cloud and Jira Server.
Best,
Sebastian.
Jack Hunter _HeroCoders_
Issue Checklist for Jira Cloud gives that possibility.
It allows to:
It also comes with a free version Issue Checklist Free.
Taranjeet Singh
 https://okapya.atlassian.net/wiki/spaces/CHKDOC/overview
You can make use of above JIRA add-on. Explore it to see if it can be used for your use case.
