How do I create a post function to auto assign to specific users based on the project?
Gordon Ngo November 29, 2016
I have multiple projects that use the same workflow.  However, each project has different leads from different groups.  At certain transitions, i would like to auto assign the issue to the relevant lead (Dev, QA, etc.) based on the Project.
Vasiliy Zverev
November 29, 2016
Replace key1 as project keis and usernames as actual user names.
switch (issue.getProjectObject().getKey()){
    case "key1": issue.setAssigneeId(ComponentAccessor.getUserManager().getUserByName("username1")); break;
    case "key2": issue.setAssigneeId(ComponentAccessor.getUserManager().getUserByName("username2")); break;
    case "key3": issue.setAssigneeId(ComponentAccessor.getUserManager().getUserByName("username3")); break;
This will assing issue to project lead:
issue.setAssigneeId(issue.getProjectObject().getLeadUserKey())
Gordon Ngo November 30, 2016
When I put that into the custom script field and update the keys/user names, I get errors on the case lines saying:
"Cannot find matching method
com.atlassian.jira.issue.MutableIssue#setAssigneeID(com.atlassian.jira.us (remainder is cut off)
Please check if the declared type is right and if the method exists."
Vasiliy Zverev
November 30, 2016
Here is updated script:
    case "key1": issue.setAssigneeId(ComponentAccessor.getUserManager().getUserByName("username1").getName()); break;
    case "key2": issue.setAssigneeId(ComponentAccessor.getUserManager().getUserByName("username2").getName()); break;
    case "key3": issue.setAssigneeId(ComponentAccessor.getUserManager().getUserByName("username3").getName()); break;
Gordon Ngo December 1, 2016
That worked.  Thank you.
