How do I create a project hierarchy in Jira Software?
Julie Mayer
December 10, 2019
We are planning to use Jira across a number of different product teams. Each team would like to have its own hierarchy or set of projects.
For example, both our mobile and portal application development teams support 2 or 3 different divisions. We would like to create the following hierarchy in Jira so that we can separate our projects from other teams using the tool. Below is an example:
Portal Application Team
  • Portal App Division 1 Project
  • Portal App Division 2 Project
  • Portal App Division 3 Project
Mobile Application Team
  • Mobile App Division 1 Project
  • Mobile App Division 2 Project
Can you tell me how I can implement something like this?
John Funk
Hi Julie - Welcome to the Atlassian Community!
As Kirstin mentioned, you should be able to get what you need from the Project Category under Project Settings > Details.
You might also want to look at the Jira Portfolio product for even greater functionality.
Kirstin Seidel-Gebert
December 11, 2019
You can use the Project Category to group projects. It can be specified in the admin section of the project (details page).
Other grouping features I'm not aware of. Such thing as a project hierarchy does not exist in JIRA AFAIK.
Kirstin
