I am inside a story or task and want to create a sub-task. I know in the list view, I can create an issue by pressing 'c'. Can I do something similar in a story or task detail to create a sub-task? I looked through the shortcut keys but did not see anything for creating sub-tasks. Did I miss a shortcut key or is it currently non-existent?
There is no direct shortcut to create sub-task but you can press the "." key to get list of operations and select create sub-task.
Really helpful, thanks a lot
That works great in the "old view". How about the "new" one? Does anyone know?
