How do I create a workflow where I have to attach a document to the issue? How can I version a document in JIRA? Basically I have a test case that I need needs to go through an approval proces.
Ana
Hi Ana,
Basically you should be able to attach a screen to the transition that you want. After this, take a look at this answer, to check how to make sure the attachment field will be required there:
