I have a Kanban board where I'd like to hide all issues related to a specific Epic from the Kanban view.
I tried using:
project = X AND labels = xyz AND EpicLink != X-123 ORDER BY Rank ASC
Hi @Todd Adel
What are you seeing when you try that filter for the board?
And, do you have issues without epics? If so, you may want to also check for empty epic link, such as:
project = X AND labels = xyz AND ("Epic Link" != X-123 OR "Epic Link" IS EMPTY) ORDER BY Rank ASC
Best regards,
That worked, thank you so much, @Bill Sheboy! I didn't save the error message I was getting, apologies.
Are the issues still showing up on the board itself or just in the Epic panel?
