How do I fix a token issue with the JIRA Clockify Add-On?
Michelle Walsh
February 21, 2025
We are receiving this error message when trying to access the Clockify Add-On for JIRA.
We've had no issues with this Add-On for a year until today.
It is not all projects.   Just seems isolated to one specific JIRA project and all of their user stories.
Jehan Bhathena
Hi @Michelle Walsh
Have you tried resetting the key once?
https://clockify.me/help/integrations/tracking-integrations-integrations/jira-integration#api-key
From the error that you get it seems that it is a Timeout, and not a validation error. Does everyone in your team get this?
Would recommend getting in touch with Clockify if resetting the api key doesn't fix it for you : https://clockify.me/help/contact#TRPLINKPROCESSED
Michelle Walsh
February 25, 2025
@Jehan Bhathena
Resetting the API key fixed the issue.
Thanks so much for your recommendation.
Like John Funk likes this
