×I faced some issues while I'm migrating from Jira server to cloud,
some of the errors are
1,The Cloud Migration Assistant is out of date
2,Your heap size is lower than the recommended size
3,Invalid email addresses
4,Multiple users have the same email address
5,Project settings will allow public access
Hi @Ulta Tools Admin ,
I will try to answer to errors for the same order.
Hope this helps,
Mayur
What about #2, any tips on where to change/check in order to rid of the warnings? can the migration process proceed with this warning?
When you expand the sections, the tool explains what you need to do. For example, invalid e-mail address...it will list out the e-mail address to correct and you must go to the user profile and update the email address accordingly.
-Ben
