How do I get subtasks to appear on a business project board?
Matt December 16, 2021
Title says it all really but this is a problem because subtasks may be assigned to different team members than the main task.
As far as I can see, these tasks would then become invisible on the business project board.
2 accepted
John Funk
Hi Matt,
Currently, sub-tasks are not able to be shown directly on the board for business projects. Hopefully, they are working on the ability to do that, but I don't know a timeframe.
There will now be an icon on the card, though, that shows there are subtasks associated with the card. You can then open the card to see the sub-tasks.
The other thing you can do is create a new board with a board filter that includes the Business project. You will need to use your personal profile or another non-business project for the Location field though.
Matt December 19, 2021
Thanks for the help 👍 Yes it felt like a workaround was going to be needed.
Like John Funk likes this
Stooz
December 17, 2021
Business project boards dont show subtasks. You may need to create a new filter and kanban board that views your project outside of the default board.
Thanks 👍
